热搜: 活动 交友 discuz
查看: 26|回复: 0
NFT Update
版主
发表于 4 天前 | 显示全部楼层 |阅读模式
Ver1.26.0328
Fixed an issue where the ECC status wasdisplayed incorrectly on the main interface MAP when the layout was set toSM3281/3280.
Corrected an error in SA ECC correction.
Ver1.26.0324
Modified the logic so that no prompt windowpops up when no matching ID is found in the database during ID reading.
Updated the block scan result interface:the list file is only saved when the OK button is clicked; closing the windowwith the X button will not save the list.
Ver1.26.0316
Fixed a bug in the exFAT file system
Fixed a calculation error in the 3-byterotation mode
Added layout and template for PS2251-09v2
Ver1.26.0314
Added layout and complete solution forSM3281v4 type
Added layout and complete solution forSG-tf
Ver1.26.0310
Added ECC, XOR and template for TF card ofIS918v4 (AS-like solution)
Ver1.26.0307
Added complete sector sorting scheme forJmSDv2
Added separated block function combinedwith page auxiliary tool
Ver1.26.0303
Fixed the bug of JmSD ecc
Fixed the bug of multi-LUN preview and eccre-reading for 0x9BC4492510
Ver1.26.0226
Fixed an error where synchronization andflipping could not be calculated correctly when the number of sectors on thecurrent page was greater than the original value.
Fixed an arithmetic overflow issue when thetotal image size exceeded 1 TB.
Ver1.26.0205
Added SLC read mode and A2, DA, 3Bcommands.
Added current cursor paragraph display inthe Byte/bit cutting interface.
Fixed some bugs.
Ver1.26.0129
Added adaptive XOR for CBM2199 series.
Fixed reread issue for SanDisk DDR chips.
Added SanDisk EF 11 reread command.
Added join CE function for reading chipswith LUN = CE.
Example: Setting 1-3/2-4 means 2 logicalCEs. The first logical CE consists of physical CEs 1 and 3; the second logicalCE consists of physical CEs 2 and 4. "/" separates the number of CEs,and "-" separates physical CEs. Each physical CE represents a LUN ina logical CE.
Fixed job save and load errors in mixedbit/byte cutting mode.
Fixed bug where sectors less than one pagecould cause errors during image cutting in certain cases.
Ver1.26.0127
Added HG2319v2 ECC XOR template.
Fixed several search bugs.
Ver1.26.0119
Added bad byte/bit editing function forcutting.
Fixed several bugs.
Ver1.26.0112
Table sorting (CBM).
Fixed incorrect file name for bad byteoperations when saving jobs.
Fixed crashes and errors caused by HG2319layout database issues.
Fixed invalid search on main interface.
Fixed crash when viewing later sectorsafter multi-image sector merging in certain cases.
Ver1.26.0107
Fixed multi-threaded ECC merging.
Added JMF618 sector sorting algorithm.
Ver 1.26.0103
Modified the Page Separation function tosupport separation by sector (equivalent to Dump Separation). Applicable whenDump Separation is unavailable due to incorrect chip parameter configuration.
Added AU8910x LBN sorting method.
Ver 1.26.0101
Added template and algorithm for Jiandiintegrated U-disk: 45409bb37e6b 2x1 (1T).
Fixed the issue where Page Separation &Combination and Dump Combination do not support images larger than 1T.
Ver 1.25.1228
Disabled native scrollbar for Hex display;implemented custom scrollbar to support 1:1 sector display for 4.7EB images.
Added ATJ3315 512x8+36+26x7 XOR ECCalgorithm and template.
Ver 1.25.1226
Added Sector Sorting Mapping TableReconstruction function. Prioritizes logical address continuity, withnon-continuous addresses as alternatives to improve the accuracy of sectorsorting files.
Fixed the issue where 3-byte flip modefails under certain conditions.
Ver 1.25.1224
Added SA display in the Block SortingConflict List.
Fixed the Swap DUMP bug.
Fixed the issue where conflict adjustmentsbecome invalid after restarting the software.
Ver 1.25.1220
Fixed bugs in the Jiandi ECC algorithm.
Fixed bugs related to saving and readingthe Block Sorting List.
Ver 1.25.1215
Fixed the SM Dynamic XOR bug that causeserrors when the number of XOR bytes is too large.
Added support for SM3281PL with planedisorder and unsynchronized XOR bytes.
Operation Steps:
Step 1: Perform normal operations untilBlock Sorting is complete; adjust conflicts of disordered planes first.
Step 2: Click Save Block List.
Step 3: Reopen the image and proceed to thepre-Block Sorting stage; select RAW Save Image. When prompted to use the savedBlock List file, select the previously saved file and click Save. The outputimage will have well-organized planes with correct sorting.
Step 4: The saved image can be directlyprocessed using any third-party software.
Ver 1.25.1212
Added multi-threaded ECC correction.
Added template for IS918v3(AS): 1140x16,blk=512, XOR ECC.
Ver 1.25.1204
Adjusted RAW Image Save: SA + ECC are nolonger saved.
Rewrote HYv1-v5 Re-read Commands.
Added function to view XOR-processed datain the Byte/Bit Cutting interface for precise cutting.
Added function to save files after openingan image.
Ver 1.25.1127
Adjusted Block Sorting Bank Truncation:Stops at the maximum LBN value, no longer pads empty blocks.
Allows users to modify the maximum LBNvalue (pads empty blocks after the actual maximum value).
Adjusted MBR Parsing: Directly displays DBRto facilitate conflict adjustment.
Added adaptive 8K-page XOR support forHG2319, PS2251-09, and PS2251-19.
Ver 1.25.1126
Fixed the issue where some re-read commandsfail to take effect when previewing or reading chips.
Fixed ECC layout issues after XORprocessing, resolving conflicts between ECC correction and merge correction.
Removed per-page status output during ECCcorrection; disabled XOR for FF-filled and 00-filled pages during ECCcorrection.
Added UP309 flip function.
Ver 1.25.1125
Added multiple structure layouts forAU89103, AS, IS918, and 20-82-515v3.
Fixed flip errors after datasynchronization.
Ver 1.25.1121
Added Cross Sector function to resolveasynchronization issues between single blocks during AU sector sorting.
Modified Bitmap function to allow imagebrowsing without opening the layout.
Ver 1.25.1120
Fixed XOR generation method for IS918 andAS chips.
Added AS sector sorting function.
Fixed exFAT file system bugs.
Fixed ECC bug in AU89103 1162 layout.
Added template filtering system.
Ver 1.25.1119
Fixed crash bugs in NTFS and exFAT filesystem parsing.
Added detailed MBR and DBR parsinginformation display.
Fixed the issue where block number inputfails to take effect in the Block Sorting Result interface.
Ver 1.25.1118
Fixed PS flip function.
Added file header detection for over 300file system types after expansion.
Ver 1.25.1117
Fixed crash caused by insufficient memoryallocation in the Block Sorting Result display interface.
Updated FAT32 file system support: Increasedmaximum capacity from 128G to 256G.
Added sector sorting template for AU89103.
Added synchronization template for SM32814x1.
Fixed AU series XOR issue: SA XOR isdisabled only during ECC correction.
Ver 1.25.1114
Added sector sorting template and XOR ECCsupport for IS918 1152x16.
Fixed CBM2199 ECC bugs.
Added sector sorting template and XOR ECCsupport for IS918 1140x16.
Ver 1.25.1111
Fixed merge correction bugs.
Fixed 8K chip reading and previewing bugs.
Fixed sector sorting and image saving bugs.
Fixed the issue where byte cutting isunavailable after deleting all operation steps.
Added block sorting conflict adjustmentfunction when opening an image.
Ver 1.25.1105
Added sector sorting support for SM3280.
Added universal sector sorting for Jiandi chips.
Added sector sorting support for AU89103.
Added universal sector sorting for SM TF/SDcards.
Added sector sorting conflict replacementfunction.
Fixed the mismatch between SA display andcorresponding sectors in the Service Area Viewer.
Ver 1.25.1030
Added basic sector sorting function.
Fixed Hex display issue: Displays all SAsegments within a page instead of only one SA segment per page.
Fixed synchronization bugs; now supportsmost mainstream controllers.
Ver 1.25.1024
Added 4-row reading and re-reading rulesfor 2C/89 QLC chips.
Ver 1.25.1023
Fixed bugs related to byte cutting, jobsaving, and dump switching for multi-dump projects; ensures cutting parametersare independent for each dump.
Fixed non-zero block display and addressoverflow issues when supplementing blocks after opening an image.
Fixed the issue where underscores appear inthe optimal command output after re-read testing; replaced with spaces.
Added wildcard search support.
Ver 1.25.1021
Fixed the bug where image cutting cannotstart from middle blocks.
Optimized search speed for fasterperformance.
Added batch search function (similar to RAWsearch, but read-only, no save support).
Fixed bank2 sorting errors for AUmulti-bank chips.
Ver 1.25.1016
Improved image cutting syntax support:Supports complex patterns like (a-b_(c-d)) x e_f-g) x n.
Added adaptive dynamic XOR for FC3379.
Added dynamic XOR for AU69XX/AU8910Xseries.
Ver 1.25.1015
Improved template and job parsingfunctions; supports swap dump and saved byte cutting parameters.
Ver 1.25.1014
Added dynamic XOR support for CBM serieschips.
Ver 1.25.1013
Added Job Save & Load function.
Fixed formula and checkbox bugs in theBlock Sorting Result interface.
Added FC1178 layout support1130+1126x7)x2.
Added dynamic XOR support for SM3280.
Ver 1.25.1010
Fixed template bugs to support moreoperation scenarios.
Ver 1.25.1009
Added XOR support for UP309.
Added XOR support for HG2319/PS2251-09/19.
Ver 1.25.0930
Added auto-execution of operations afterloading a template.
Ver 1.25.0924
Added adaptive dynamic XOR for SM chipsafter byte cutting (supports SM3281, SM3271, SM3259).
Fixed multi-chip display bugs.
Ver 1.25.0905
Added ECC XOR support for FC22791152+1148x7)x2.
Added ECC XOR support for FC3379:1158+1154x15.
Ver 1.25.0903
Added ECC XOR support for FC1178 v2.
Added ECC XOR support for FC3379 v2.
Ver 1.25.0827
Added function to save the current-stepimage (including Service Area) when selecting RAW algorithm.
Modified Bitmap display: Added paragraphend line segmentation; adjusted X-axis arrow to 1-slider movement and Y-axis to1_32 scaling (consistent with default 3K display by default); fixed bit cuttingbugs.
Ver 1.25.0811
Fixed several bugs to improve overallstability.
Added temporary search function.
Ver 1.25.0807
Added and fixed FC1178 algorithm for TLCchips:
Directly supports SLC block XOR.
Automatically distinguishes SLC and TLCblocks during sorting.
Implements independent separationoperations for the two block types, with merged results supported.
Ver 1.25.0804
Added English interface; supports bilingualswitching.
Fixed address acquisition errors in theRe-read Test interface.
Modified chip parameter settings to takeeffect immediately in the Chip Reading interface.
Updated re-read command syntax: Add"/" suffix (e.g., Sandisk v3 / fe fa fb fc fd ff f9).
Added log editing functions in the maininterface: Support Ctrl+A full selection & deletion or mouse drag selection& deletion.
Ver 1.25.0728
Fixed voltage setting bugs in chip previewand reading functions.
Added ECC support for ATJ2259.
Added ECC support for Lexar MS card: 539x8.
Added ECC support for HG2319: 1158x16.
Ver 1.25.0722
Added conflict block display &replacement function.
Fixed SA information display errors.
Revised the Block Sorting Result displayinterface.
Added image cutting function.
Ver 1.25.0716
Added Block Sorting function andcorresponding interface for FC1178.
Fixed operation deletion bugs.
Added chip sequence adjustment function.
Added Service Area Viewer function.
Completed Chip Preview function (fixedseveral bugs).
Ver 1.25.0625
Fixed potential address calculation errorsduring re-read operations.
Fixed ECC-related bugs.
Added ECC hardware re-read library valuetest function.
Ver 1.25.0521
Enhanced Sector Cutting function: Supports decimal/hexadecimalformula conversion.
Reconstructed the Byte Cutting functioninterface to improve user experience.
Enhanced the stability of the Bad ByteCutting interface to prevent abnormal crashes.
Optimized the calling process of the BadByte Cutting interface to improve response speed.
Ver 1.25.0425
Rebuilt and enhanced Merge Correctionfunction; added data filtering features.
Fixed merge errors in the Re-read Testfunction to improve test accuracy.
Added ONFI protocol reading function tosupport more storage devices.
Added re-read command support for YMTC V1controller.
Ver 1.25.0212
Enhanced image parsing function: Supportsselecting logical sectors corresponding to files.
Optimized CBM dynamic XOR algorithm toadapt to more storage device structures.
Added stepwise Hex jumping and USBdetection functions.
Added integrated disk wire sequence sortingfunction to assist wire sequence adjustment.
Ver 1.25.0117
Extracted XOR and data segmentationfunctions to enhance data processing flexibility.
Added resume capability for ECC correctionto avoid restarting after interruptions.
Added library value support for HY1245controller to improve data processing capability.
Ver 1.24.1213
Added LBN XOR support for AU controllers.
Added 16K XOR support for AU controllers.
Added ECC support for HG2319.
Added power supply parameter adjustmentfunction to support voltage regulation.
Ver 1.24.1118
Added Read Retry command support forIntel/Micron, Samsung, Sandisk/Toshiba, Hynix, and YMTC chips.
Added multi-type ECC support for FC2279 (30sectors), FC3379, and BR6998.
Ver 1.24.1110
Released NFTracer Initial Version: Supportsbasic ECC detection and correction functions.
Archiver|手机版|小黑屋|NAND Flash Tracer
GMT+8, 2026-4-3 03:45 , Processed in 0.068074 second(s), 30 queries .
