查看: 349|回复: 0
2. Loading the dump
超级版主
发表于 2026-4-4 10:42:12 | 显示全部楼层 |阅读模式
1. Select theimage file: Image file naming convention: chip number_channel number.dump. Ifit matches the convention, the current image file will be automatically loaded.All files in the directory.
2. Select ID: Iffe\chip.txt exists in the image directory, the ID will be automaticallyretrieved. The process will pause if the ID is not unique. The user can choosean ID that matches exactly.
3. Manualselection:
1. Enter the idand press Enter to find all matching values. Double-click to select andconfirm.
GMT+8, 2026-11-4 18:50 , Processed in 0.052892 second(s), 19 queries .
