查看: 663|回复: 0
NFT Will Add Full-Link LDPC Hard/Soft Decision Error Correction Engine
发表于 2026-7-7 15:37:46 | 显示全部楼层 |阅读模式
I. Industry Pain Point: Long-Standing Technical Barriers in Data Recovery for New-Generation SSDs
With the widespread adoption of 3D TLC/QLC flash memory, Low-Density Parity-Check (LDPC) codes have become the standard error correction solution for solid-state storage.
Conventional flash/SSD recovery software only supports error correction via the legacy BCH algorithm and cannot process the new LDPC error correction scheme at all.
II. Major Technical Breakthrough: Self-Developed Full LDPC Hard & Soft Decision Decoder Officially Launched for NFT
The technical team of Dalian ByteSmart Technology has dedicated years to underlying flash memory reconstruction algorithms. Building on mature data recovery solutions for USB flash drives,
TF cards and embedded chips, the team has fully self-developed the complete stack of LDPC decoding algorithms.
NAND Flash Tracer (NFT) is now equipped with a dual-mode error correction engine supporting both LDPC hard decision and soft decision decoding.
This delivers a leap forward in recovery performance for faulty SSD data and fills the global gap of chip-level recovery tools supporting LDPC soft decoding.
Core Technical Architecture
The software integrates a standardized intelligent error correction pipeline with no complicated manual parameter tuning required;
repair logic runs fully automatically:
1. Import or read raw flash image files and initiate basic LDPC parity check.
2. Prioritize high-speed hard decision decoding: fast iterative bit flipping based purely on binary 0/1 values.
    Pages with low bit error rates can be corrected with one click, delivering fast decoding speed and high efficiency for batch processing.
3. If hard decision decoding fails to correct all errors, read chip data via multiple read-retry schemes to generate soft decision dependency files.
4. Launch in-depth soft decision decoding: leveraging confidence data from voltage intervals to accurately identify ambiguous bits
    caused by threshold drift and charge loss, greatly boosting extreme error correction performance.
5. Verify page integrity after two rounds of decoding. A clean image will be exported once all errors are corrected.
III. Core Product Advantages Tailored to the Business Demands of Data Recovery Labs
1. Full-medium compatibility covering both flash memory and SSD recovery scenarios
NFT’s original features support data reconstruction for USB drives, SD/TF cards and IoT embedded storage chips.
Following the LDPC engine upgrade, the software offers full compatibility with all solid-state drives built around the LDPC error correction framework.
A single tool handles all types of NAND flash devices, eliminating the need to purchase multiple separate tools and drastically cutting hardware procurement costs.
2. Adaptive dual hard/soft decision modes balancing efficiency and maximum recovery capability
High-speed hard decoding is prioritized for minor errors, enabling smooth batch processing of thousands of image pages.
For severely aged drives or devices suffering heavy charge loss, the system switches to deep soft decision repair,
with hard and soft decoding schemes complementing each other.
3. Self-developed underlying algorithms with no reliance on third-party kernels
The complete set of LDPC decoding matrices, iterative flipping logic and LLR confidence parsing algorithms are independently developed in-house.
The tool is deeply optimized for workflows in data recovery labs with straightforward parameter configurations,
allowing operators to get started without advanced knowledge of complex communication coding theories.
4. Full-process visualization lowering technical barriers
Parameter configuration, decoding progress and other status information are presented in the same format as the original ECC error correction workflow,
ensuring seamless, transparent operation with zero learning curve.
IV. Industry Value
This breakthrough of the LDPC hard/soft decision decoder marks a milestone transformation of NFT from a "flash memory recovery utility"
to an all-in-one underlying NAND data reconstruction platform supporting all flash product categories.
If you struggle with unrecoverable data from heavily aged solid-state drives, explore the full feature set of NAND Flash Tracer (NFT).
Hard-Decision Correction Result
Soft-Decision Correction Result
GMT+8, 2026-11-6 00:22 , Processed in 0.058805 second(s), 21 queries .
