查看: 24|回复: 0
Instructions for Native L2P Table Analysis Function
发表于 昨天 13:52 | 显示全部楼层 |阅读模式
1. Set Block Attributes
    Setting block attributes is a prerequisite for using the native table analysis function. Before native table analysis, SLC blocks must be assigned.
    There are two ways to assign SLC blocks: automatic scan and manual assignment. The result of automatic scan is for reference only.
    To ensure the accuracy of block attributes, it is recommended that you verify the result after automatic scanning.
2.  For multiple dumps, perform the Combine Dump operation directly.
3.  Native Table Data Analysis When running sector sorting, check the option Native L2P. The sorting output will be the result parsed from the L2P table.
Notes:
* NFT still keeps the original sorting method (without checking "Native L2P"). You can choose either method as needed.
* Block attributes must be set as the first step after loading the image; no other operations should be performed beforehand.
* Do not modify block size or page size before sector sorting.
* This function is only available for images that require sector sorting.
* It is recommended to set ECC status to OFF for faster processing. However, some IS918 models will throw an error quickly when ECC is OFF. For these models, ECC must be set to ON.
GMT+8, 2026-10-23 16:26 , Processed in 0.045811 second(s), 18 queries .
